fairlaniac
- Sep 24, 2011
- 5
- 17
I may have found my issue. See pics and page from manual. Item 226 is "Bracket Mount Torque". If you look there are to be t screws item 125 that come in from the front through item 80 "Bracket Strap Torque" and then there are two more screws item 125 that come from the top and through the two hole in the top of item 226. Well as you'll see in the one picture, item 226 (angle) the two hole in the top are mangled up. There are also seration marks from screws that once were there. So no screw and I cannot figure out what those top 2 screws (item 125) screwed into? Does anyone know? It looks like in the one picture looking from the ground up that two cast aluminum fins on the housing are broken. Is there to be something there to bolt onto with the angle bracket item 226? Looks like I'll be fabbing up something to stabilize the torque as it appears the belt coming off is attributed to the axle rotating forward. Anyone disagree? Who would have designed those thin fins to take the torque? I'm sure the two screws came loose and the vibration busted the fins (if they were there). Oh well, out to the garage.
Again I apologize if I semed to hijack the thread. At first I thought we had a common problem. I'm going to copy this on my original post on the topic.
Thanks to all!
PDF of manual showing item 226 http://www.fairlanet.com/images/lgt2654 chassis.pdf
Thanks to all!
![lgt2654%20001.jpg](http://www.fairlanet.com/images/lgt2654%20001.jpg)
![lgt2654%20002.jpg](http://www.fairlanet.com/images/lgt2654%20002.jpg)
![lgt2654%20004.jpg](http://www.fairlanet.com/images/lgt2654%20004.jpg)
