Mowing fine had just mowed about 3 acres with Hustler Mini Z. 19hp. kaw. air cooled. It has about 550hrs on it. Have never had a bit of problems and always starts fine. It is the FH601v engine.
1. Blades stopped and motor immediately shut off
2. Blade switch was still engaged so dis-engaged and attempted to restart
3. The starter is visibly trying to crank the motor - I took the shroud off and you can see it trying to move the flywheel
4. The flywheel moves about a half an inch but the motor will not turn over.
5. The motor fins are not plugged the oil is at Full level and is clean just changed it couple mows ago.
6. The motor did not smoke or make any loud noise just shut down after the blades did
7. looked under and do not see anything caught under blades or clutch - I can turn the blades by hand.
8. It acts like the blade clutch is still physically engaged even though blade switch is in the off position.
Questions:
1. Would the flywheel move a half an inch if the motor was seized.
2. Have you ever seen the clutch that engages the blades from the motor stay engaged when the switch is off
3. Any ideas what this could be?
Thanks
Questions:
Thanks
