Mower Deck Undercoating
djdicetn
With your mulch kit now installed, do you have to mow more frequently so the grass is not taller thus allowing your mulch kit to work better?
I installed it at the end of last summer, so I'm not certain I have noticed any difference in the growth rate of the grass. I still cut just once weekly and won't cut more than 1/3 the total height. Now if we have a very wet summer I may have to mow every 4-5 days instead of once every 6-7 days like I am now. It's still early in the growing season and I can't see a need to change.......yet:0)
P.S.
Hope you didn't take offense to my earlier statement about the "stamped deck" JD has on all but it's top-of-the-line ZTR's. That 7-Iron deck is considered "the Cadillac" of stamped decks and will definitely outperform anything else you compare it to that also has a stamped deck. You will have to post some pictures of your lawn after mowing as I'm certain it will look excellent. In other words, I would be inclined to buy one of those Z960R's if I had the money(I set a limit of $7K when I was shopping ZTR's and my Gravely came in just under that...$6,800 otd).
Nwatson99
P.S.
Heavens no I did not take offense, I am just trying to learn and be prepared for what to expect with this new MOD deck.
I know it is not a full time mulch unless I want it to be and only plan on using it around the immediate house, drive way, pond, so I was just curious if you were able to go between normal mowing periods say every 7 days or you had to change to every 5 days now due to the mulch kit?
