mower deck coating
JDB
What do you use to coat the under side of a mower deck? I have a 1995 LX 178 JD and the deck is getting pretty rusty underneath, I was going to paint it but I hope there is something more durable out there. Thanks,
Briana
Hello, I have moved your post to the General Mower Discussion Forum. You will have better luck finding assistance there. :wink:
Thanks for joining LawnMowerForum!!!
KennyV
Clean it up and coat it with a rust converter like POR-15...
POR-15 RUST CONVERTER
There are other brands that work equally as well.. :smile:KennyV
173abn
as Kenny said,rust converter which you can get at TSC and auto parts stores and I also use MoDeck a spray on lubricant you can also get at TSC,others have suggested PAM.The stuff you spray on your skillett.Never tried it but some swear by it...russ
