Mower cuts off and/or sputtering
Shaver702
Hey! I’m at a loss….
I have a mower that will run fine for a few minutes till it gets warmed up then will cut off off or sputter till it does.
I have new spark plugs
Air filter
Ignition coils (OEM)
PTO switch
And I have taken apart the carb a few times to make sure it’s still cleaned. Everything was clean even the jet.
any ideas?
Here is the link to the video I took
https://skanska.box.com/shared/static/xdzhtc9h0yhttxolsrvnxcv2k3s07lc9.mp4
Sounds like a fuel issue. If the carb is clean, check the fuel filter. I'm assuming it's fresh gas...When it dies will it restart and repeat the cycle?
