Mower Bogging Down
HarryHarley
Try letting the grass discharge out the side instead of mulching...
exotion
sounds like throttle needs adjusting? or lost compression. maybe new coil?
scotth1
Following the advice of the last poster, I did some research on symptoms of a bad ignition coil. They sounded very much like the problems that I was having, so I went ahead and replaced it. Tonight I was able to mow the lawn without any problems, so we'll see if that is the fix I was looking for.
