The Reel Mower weighs 270 lbs and has a split roller, full differential for high speed cornering.
Cutting Lawn at 1/4 of a inch height........looks like a golf green when finished mowing:biggrin:
How wide is the cut?
Consider that a brisk walk is 3.5 mph. You're not talking kph, it's mph right?
So you are pushing 270 lbs at 4.2 mph, how far can you do that?
.... it cuts 28 inches wide and has a 9 Horsepower Honda engine which pulls you along.....up to 5 miles per hour.
