Did you take the fly wheel Off ? I had one the the key looked great from the top but was gone underneath.Series 1000 cub cadet. Hit a tree stump and motor stopped and will not start. Keyway is intact. Piston moves when engine is turned over bottom pulley moves normally. Any suggestions?
Say it again.....Did you take the fly wheel Off ? I had one the the key looked great from the top but was gone underneath.
My thoughts also flywheel must be pulled.Did you take the fly wheel Off ? I had one the the key looked great from the top but was gone underneath.
