jhngardner367
 - Mar 1, 2014
- Threads
 - 2
 - 40
First,check the air gap for the coil(s). They should be 0.010". Also,try spraying some fuel into the intake,while rolling it over.and see if it runs,or backfires. If it backfires through the intake you could have a valve hanging up.
If you pull the engine case apart, check the timing marks,carefully.
