Repairs motor swap
brettly17
i have a craftsman yt3000 with a single engine briggs and stratton (model 331877 type 2371g5 code 110419zd) looking to swap in a new engine as i blew mine up looking at putting a briggs and stratton 24 hp 44N877-0008-G1 in it will this work? the crankshaft is same diameter length and keyed the same way just not sure with room and bolt pattern for these engines. thanks much :confused2:
The bolt pattern is the same. Now you need to see if you have enough room. I'm sure you do . Better safe than sorry the new motor will list the dimensions or you can Google them. Then measure what you have available. One issue will be the exhaust. Some others here have done these they can tell you more.
