Motor starts to go up and down after half a hour
JohnHendrikx
So I have work to do and hope to find the issue
Many thanks for the information and advice!
John
hlw49
When it starts surging pull the fuel line from the tank loose and see if you are getting good fuel flow from the tank. I have seen fuel lines collapse when they get hot.
zigyblu
I would remove the fuel cap and see if it smoothens out and if it does your vent hole could be plugged. That should also help get a better flow of fuel to the inline filter.
peteco
Also check the coil, when get high temperature, probably fail. In old cars it´s the same.
hlw49
Try holding the governor arm still and see what it does. If the engine dies it is a fuel problem if it keeps running and smooths out it is a governor issue.
