Model 247.372370 Top Plastic Cover
SMWoody
Greetings: I'm trying to take the top plastic cover off of a Craftsman walk behind mower (model 247.372370), i've removed the 2 screws that hold it on the engine but there is something holding on from the front - I can't see anything and i really don't want to break it - i've found nothing on the WWW on this and the parts illustration from Sears is......well i don't have anything good to say about that.....any thoughts? Thanks in advance.
Jack17
You should go to Briggs & Stratton, punch in engine model# and the search should give you a nice engine diagram and how to work on it. Good luck.
Front has a plastic tab with a barb on it, pull back while rotating up.
Google the part and you might find an image of it.
SMWoody
Finally got the cover off - and I'll save my rant about that for another place/time - thanks so much everyone!
