Model 130292 will not run unless fully choked
If you're choking it to make it run, it's starving for fuel , you still have a fuel problem with the carb or fuel pump diaphram
Hi Bertrrr, I do realize that and have been very careful to do it right with the install. Even replaced the diaphram, just doesn't make sense!
Hi Bertrrr, I do realize that and have been very careful to do it right with the install. Even replaced the diaphragm, just doesn't make sense!
