Several years ago, I mowed with a 2135 and the PTO developed intermittent operation. I found a 2165 which had been used to tow a salt spreader; as a result, the footboards were rusted through but the PTO had never been used. I bought it for $200 as spares for the one I was using. The 2135 PTO problem turned out to be the push-on wiring connector, so the clutch never had to be replaced.
The 2165 started and ran perfectly, but closer inspection found a cracked right front kingpin housing on the axle end. Bought a used axle for $30.
One dark night, the 2135 was stolen, so now the 2165 had no purpose, so it needed to go away. I thought it would be worth more if it had a functioning mower deck. After years of searching craigslist, today, I found a perfect 48" deck with the fan-assist bagger blower for $100.
So now, I've got $330 in a mower which I don't really need and will end up selling after several hours of labor to get it fixed up.
Any guesses as to what a 2165 mower is worth these days? Pictures to follow soon.
jack vines
jack vines
