missing drine plug?
ice
Hello all.
I have brought a Poulan mower. that needed a lot of work. I am almost done with it. I have some small loose ends.
There are 2 holes on the transmission .the one with the hex does not belong there. Falls off. Does anyone know what size bolt goes there
? And where to get it?
I hope the pictures are clear enough
that is where the transmission vent goes. It is actually two parts. Part number 70109 and 70110 which are hydrogear part numbers. Go see your mower dealer, they should also be a hydrogear dealer.
ice
Hello ILengine,
Thank you so much for the info.
would you have a picture of that by chance?
it looks like from another diagram that there is a 4 inch piece of hose/tubing between those two parts. part 532142564 can't locate picture of part. if you get the other parts you should be able to come up with a piece of black rubber heavy wall tubing to use to raise the vent up out of the way.
ice
thank you so much
do you have your own shop? I am starting a new thread on the belts. they are both the wrong size. I would like to order all the parts from the same place.
