Hey guys
I have a mid 90`s 42" yardman riding mower. My problem started out that gad was getting into oil while it sat in between use.
So I replaced the needle, the needle seat and the float. After doing so the problem still persisted. I then put a gas shut-off on the main line and figured this would fix the problem.
I am still getting gas into my oil while the mower is in use....
Does anyone have any ideas or fixes????
I am open to ideas and suggestions and much appreciated.
I am not a licensed mechanic but can usually figure things out. This has me stumped..
Thanks in advance!
Tony
Thanks in advance!
Tony
