I need help troubleshooting the issue with this engine. It's a Briggs and Strat 128602-0304-E1 on a Craftsman mower. Here's what I've got so far:
• The engine does start and run
• There is a terrible terrible metallic clunk sound while starting and running
First thing I did was pull the spark plug cord off and pull the starting cord to see if it still made the sound: it does.
I have also done the following:
• Removed starter coil cover and verified that noise is not coming from the starter rope assembly (it isn't).
• Removed the flywheel cover and verify the flywheel key is not sheered and there is not debris anywhere.
• Removed the valve cover and verified valve operation.
• Verified the blade is not loose/bent/etc
All of the above tests checked out.
I finally discovered that if I remove the spark plug and crank the engine by pulling the starting cord, there is no noise at all. With the spark plug in, the noise is present. I tried several different spark plugs, same result.
My initial thought is that it is a broken rod, but I would think that with a broken rod, the engine wouldn't start.
What else can I do for troubleshooting beyond disassembling the engine complete? Any thoughts as to what this could be? The engine ran perfectly up until this noise started mid-mow out of the blue.
