Turbodriven
 - Aug 18, 2023
- Threads
 - 11
 - 84
I'm completely lost here. Hopefully someone here has some deeper knowledge than I can seem to find.
I have a Kohler CV740 (27hp) motor on a 2005 Gravely 260z. No plate on the motor, must have fallen off. I have a black "Smart Spark" box though on the side with the number 24 584 27 on it. And coils with the numbers 24 584 15 on them. These coils have a brown wire and a yellow wire going to each unit. According to the Kohler manual on page 38 (item L) it says that yellow wires indicate that I have an ASAM (analog speed advance module system). I've heard conflicting info on that though. Someone with yellow wires has insisted to me they had a DSAM and didn't replace the flywheel during the conversion with positive results.
That being said, I'm pretty sure that if I do in fact have ASAM, that I need a flywheel replacement with the MDI conversion? Ok, so in a late night haze I ordered the 24 755 307-s conversion combo which includes the MDI modules, harness AND a flywheel. But then I discovered that might be for the 22-23hp Commands? And 24 755 308-s is for the 25hp commands. But nowhere does it list the contents of each package. Are the components the same, except the wire harness maybe?? Or is everything different? None of this information is easy. Shame on Kohler for making it so confusing.
