Locksnapper
Hello all
i have recently bought a second hand McCulloch M46-500 which has a Briggs & Stratton series 500 engine.
in using it for the first time, it started well, but as I went through more dense grass (no hugely long - newly laid lawn approx 6 weeks old) it stopped self propelling - so I thought I would have a look!!
i tipped it on its side , carburettor side up. I noticed that the drive belt guard was broken, and the pulley in the gear box was heavy with grass, which I cleaned out. I then took the blade off (in order to take the guard off. To take the blade of I used a set of grips on the in blade support to get some purchase, then removed the centre bolt.
I then put it back together in the reverse order, but trying not to over tighten the blade.
to my horror when I put the lawnmower upright again there was a lot of oil dripping down the chassis, from the exhaust region, onto my brand-new patio (my wife doesn’t know this yet!).
I wpied up the oil from around the engine and where it had pooled on the chassis. UnSurprisingly when I went to start it it would not start, and the pull string was hard to pull, with a lot of vibration.
I did some googling, and as a result when I remove the spark plug it was a lot easier to pull over. I cleaned the spark plug and tested it and there appears to be a small spark. I took off the air filter, that was saturated in oil. I removed it and the air filter housing and clean them out. I could see by pressing the priming pump that there was fuel going to the carburettor.
in a bit to clean out the chamber I pulled it over number of times without the spark plug in. It pulled over easily with some resistance, I also put my thumb over the spark plug hole I could feel pressure pushing my thumb back when pulling over. However, when I replaced the spark plug it was tough to pullover and there was some knocking noise from underneath (Felt like the blade was vibrating?)
so today I’ve had another look, I tipped it around 45° this time to have a look at the blade. That seemed loose I could move it very slightly backwards and forwards without it moving the blade support. I therefore tried to tighten it up once more. In doing so when I tighten the bolt (with the blade jammed), The whole mechanism turned clockwise, therefore I was unable to take any further.
when I put the mower down again, once again I had some drips Of oil, not nearly as bad this time.
so that’s where I am, so I’ve what Have I done wrong, and how do I fix it please? If pictures would help let me know.
any help appreciated guys
Locksnapper.
Locksnapper.
