massive oil leak
burginater
i just recieved a husky yth2148 with a 21 els 656 briggs, massive oil leak coming around the bottom of block, doesnt seem to come out of head gasket,allready replaced the head gasket on the left side,ran great till hot then oil started pouring out,any idea where the oil leak be from
Most likely location would be the sump gasket. Tends to get brittle and gets sucked in causing an oil leak.
