Though Masport (Made in New Zealand) isn't listed in the forum's brands, the engine it's fitted with is a B&S one (675 series engine).
As part of the maintenance schedule you have to grease this chain annually, once you've removed
all the dead grass!
That part is easy, but I'm hoping someone can give me some clues on refitting the chain; every 3
years you have to clean & grease the chain under black cover, as in photo; to do this you
have to remove the chain obviously to access screws to remove black cover.
Last time I removed the chain I really struggled to refit the large chain, and wonder if anyone
can share any tips/tricks? I found it virtually impossible to rejoin the chain and then insert the split pin;
just didn't have the strength (or gadget) to bring links together.
Thanks & take care.
(Also attach extract from Masport Service Manual)
all the dead grass!
Thanks & take care.
