Attachments M665 Zero Lighting Hook up
carhart4169
Looking for the best place to tap into the wiring harness for lights.
Thanks
Carscw
Go right off the battery
JD318420
I agree, separate circuit off battery, with a fuse, switch and then the lights. Now if the current draw is heavy you might then use a relay also.
