2nd hand LX277, pulled it out of storage yesterday, mice made a nest under the hood and engine shroud.
Cleaned all that out and noticed a small black wire not connected to anything that comes from the wire loom under the battery into the connector by the block. Looked to no avail for the other end of it.
Pressed on, cleaned everything up and tried to start it up, as soon as I turn the key on the started engages but it wouldnt fire. Gave it a shot of ether to see if it would kick and nothing, gave up for the night!
Came out this morning and flipped the key on and it coughed to life, sputtered and died, OK good should be ok, buttoned everything up and tried again and nothing, pulled the plugs, no spark, but I had a spark 20 min earlier.
Cleaned the plugs up and put them back in, hunted around for a broken wire or anything out of place, nothing except the small black wire mentioned earlier. I had disconnected the connector at the block while I was cleaning and forgot to put it back together, turned the key and it fired right up, ran fine, left it running while I put the hood etc back on, of course the key is in the off position and it's running, noticed the connector was apart and I connected it and she dies.
Thoughts?
Bad key switch?
any idea what that black wire may be? I'll try to get a picture for clarification
Thanks in advance
Thoughts?
Bad key switch?
Thanks in advance
