LX188 With Kawasaki motor.
tiger29
When removing solinoid does it go back in a certain way.
on the starter.
Scrubcadet10
Moderator
Staff member
Cables hooked up correctly?
does the solenoid run when you turn the key, or all the time?
Mower King
All the time
Take the starter off and bench test it, that way you can see if the solenoid and starter motor are working correctly....if they are both working correctly, you have a problem, in front of the starter!
tiger29
Will do but will take some time. Let you know when I get it down.
tiger29
All the time
Thank You S
Thank you Mower King!! I took the starter off the solinoid was not hooked up right inside the starter. After all this time YOU got er done!! (Thanks Again)
