LX188 With Kawasaki motor.
Take the starter off and bench test it, that way you can see if the solenoid and starter motor are working correctly....if they are both working correctly, you have a problem, in front of the starter!
Will do but will take some time. Let you know when I get it down.
All the time
Thank You S
Thank you Mower King!! I took the starter off the solinoid was not hooked up right inside the starter. After all this time YOU got er done!! (Thanks Again)
