The starter solenoid isn't engaging. Battery connections are clean, new and tight. The battery's at 12.6 volts currently. Same measurement at statrter post and at the wire coming off the battery that feeds the key switch. Dash lights work etc, carb relay works, main relay I can hear click also. PTO can engage etc.
With key OFF my meter registers "0.01" volt at the wire that goes to the relay that then goes to the starter solenoid.
With key to "run" my meter shows about 1/4 volt.
With key to "start" my meter shows around 1.5 volts at that wire.
Am I being dumb, or shouldn't that wire be at ZERO volts unless the key's at start, at which case it should have 12v?
