BluegrassBanjoPicker
- Aug 18, 2017
- 3
- 4
Hello...I need to replace the carburetor on my JD LX176...part of the metal housing is cracked. It has a K Series Kawasaki engine. The engine number is FC420VA26921. The code is FC420V-AS10. The problem is I can't afford an OEM replacement ($185-$215) and I can't find an aftermarket model. For some reason it seems the Kawasaki AS10s are way more expensive than other Kawasaki carbs. Does anyone know if there is a less expensive Kawasaki or other carb that would fit this mower? Barring that, does anyone have a good used carb they would be willing to part with? Any advice is appreciated. Thanks.
