Lx 255 starts fine but then stalls after about 30 minutes. I replaced the spark plug, air filter, and fuel filter but did not help. It has a kohler cv15 engine. Only other thing I noticed was that the battery light stays on which that never did before. Do not know if battery would cause this or not, but I checked the voltage when cranking and it did not drop down much at all. I downloaded the cv15 manual, but that was way over my head. Any suggestions would be greatly appreciated.
Forgot to mention that problem started after we moved, and I had to drain as much gasoline as possible out of the tank before loading it on the van. Could that cause this?
