New to forum! While helping my son grease his Tiger Cub,could not find the fittings for the brake actuator. It is #3 on the lube chart and point's to the rear wheels.
Is the use of the white grease for the spindles necessary or can you switch to the same grease used on the other fitting's ?
Thanks for reply's ,my son wants to maintain his machine the right way.
