cruzenmike
- Feb 10, 2017
- 59
- 858
Hello all. I need help solving a problem. When I press the drive pedal on my LTX1050, it makes an obnoxious noise from beneath the middle of the machine. The noise only occurs right before the machine starts moving. Once the machine is in motion, the noise goes away. It is hard to explain the noise itself, but I would call it a maon rather than a whine. It isn't the hydrostatic from what I can tell, because that sound I can hear from the rear when I am moving. I believe this issue to be the result of some bad idlers under the machine. There are two v-belt idlers and one flat idler on the bottom of the floor pan. One of the pulleys has some play (slight wobble) and one of the others makes a sound when spun by hand. Only one of them is smooth and quiet. I was hoping that someone either knew of this issue or fixed this issue before and can point me in the right direction? Help is appreciated. Thank you.
Mike
Mike
