DHiggins21
- Apr 2, 2020
- 1
- 3
I started having an issue with my LTX1040 riding mower last summer where it was acting like I was releasing the accelerator pedal. I would have it pressed hard down and the mower would just come to a stop. If I release the pedal then press it again, it will take off like it is going to go full speed, but it immediately comes to a stop as if I don't have the pedal pressed down anymore. If I do get any movement out of it, it is very slow and eventually comes to a stop, especially if I attempt to go up the slightest bit of an incline. My upper and lower drive belts seem like they are in good condition and seem like they are as tight as they should be. I dropped the engine pulley out and messed around with a few things just to see if it was anything obvious and when I got it all back together it seemed like it was fixed but it only lasted about a minute or so then it started acting up again. I bought a new drive belt but I wanted to see if anyone on here has had this same issue before I change it out. I'd rather not spend a bunch of money guessing which parts to replace. I know it could be a number of things but I'm hoping someone can give me a better idea of where to start. Thanks!
