LTX1040 2010 Key Issue
MAguln8839
I have a 2010 LTX1040 mower. When I try to start it and turn the key to the on position I see the dash light up, the Voltage says between 11-12v, but the mower does not turn over. If I jiggle the key around and shut it off and on a few times, it turns over. Tried a brand new battery, same issue. Even after its warmed up same issue. Anyone run into this before? Possibly a bad ignition switch??? Thanks in advance.
Carscw
Un plug the wires from the switch and clean the contacts. If does not work replace switch
MAguln8839
Thank you very much Carscw, poor contact, cleaned it and it resolved the issue. Thanks Again. I owe you
Take Care,
Mike
