LTX 1050 WON'T TURN OVER WITH KEY
bobvan
HI, i AM HAVING A PROBLEM WITH THIS TRACTOR. BATTERY IS CHARGED, BUT NOTHING HAPPENS WHEN I TURN THE KEY. I HAD MY SON SIT ON THE TRACTOR, TURNED THE KEY ON AND USED A CAR JUMPER ON POSITIVE STARTER TERMINAL AND TOUCHED THE NEGATIVE TO THE FRAME. IT STARTED RIGHT UP. BAD KEY SWITCH OR ????
Blown fuse ?
bad battery ground connection ?
