I've just acquired a used LTX 1040. The blades are misaligned, probably when the previous owner replaced the belts. There are clearly timing marks on the notched pulleys that drive the blade to prevent the blades from hitting each other. The manual I downloaded doesn't show what the proper orientation of the timing marks is. Does anybody know which way the marks should point?
