LTR 180 2003
666
HOW DO YOU MAKE IT ROLL BACK . WITH OUT STARTING IT UP . ::confused2:
WELCOME TO LMF!
Maybe put it in neutral or something....I don't know much about riders. :confused2: Hopefully since I responded others will see this post and respond also.
Good luck!
Briana
Welcome to LawnMowerForum.com. :smile:
I moved your thread to the John Deere forum. Good luck!
Frog
I have a 2007 LT180 and if your is hydro drive there shold be a little metal handle on the back above where the hitch is. If you pull it out it releases the hydro, push it back in before you try to drive it.
SeniorCitizen
Let me suggest obtaining an Operator's Manual. The information in some of them isn't very detailed but cover operation and often do explain the basic maintenance like belt changes etc.
Those are nice lawn tractors, enjoy it. :thumbsup:
