Hello Everyone,
Toward the end of the last season I noticed that the mower was going slower and slower. One time I took it out and it wasn't moving. I looked around and it appeared that a stick was jammed in underneath so I took that out and everything seemed fine for awhile but there is still an issue. For starters, it won't go in reverse at all, no pressure to drive it backwards. With forward, I can step on the accelerator 2-3 times and have it do nothing and then sometimes the 4th-5th will make a whining noise and go slowly forward. I took the deck off yesterday and jacked it up to look at it. When in the air, the tires are able to move freely, so doesn't seem like a lock up. I took the bottom transmission bracket off to look at the springs and bars and everything looked in order. The pedals would move the associated linkage on the rear differential. I started it up and the motor drive shaft was rotating but I will not that the rear fan wasn't moving.....not sure if its suppose to or what other clues I should look for but any ideas?
