LT2000 running problem
bbmeister
I have a Craftsman LT2000 Kohler powered tractor. I'm having a strange problem, when I start it, it starts fine. As soon as I release the brake and the brake release lever it stalls out. No sure, but it seems there may be a switch that's bad, just guessing though. Is there a swith on the brake or the brake release lever?
Thanks in advance
Bob M.
Scrubcadet10
Moderator
Staff member
I think it may be the seat switch, when you release the brake it is sensing no one is in the seat.
What is the model number of the tractor? Should be located under the seat
