I will be cutting grass great for 10 min and then the motor starts to run like its starving for gas. So far I have changed the gas filter and pulled the carb off and taken off the gas cap. Sometimes I can cut the grass 2 or 3 times without a problem. Any ideas i don稚 think it is the gas pump. I also have a weak reverse not as fast as i use to be is there a way to check or adjust the tranny.
Thanks this my first time on this web site.
