If the carb just has a plug, the fuel solenoid wire can just stay unplugged. But if you install the solenoid, you must install the power wire.
Quote, Yes, made sure it pumped enough to fill bowl in about 5 to 10 sec. ( Is it Gas ) :ashamed:
:confused2: You are still not getting fuel to go into the carb from the pump :confused2:
Your sparks plugs are dry after a good 15 seconds of trying to start with full choke? Is your gas, good gas. LOL Maybe someone dumped water in your tank.
I thing we covered everything except choke, manifold leak, plug muffler, bad cam lobes. :mur:
