Hello all,
Title says it - PTO will engage only when moving...but if the PTO is engaged, I can stop mowing (engine running) and it will continue to engage just fine, until I push the knob in to turn it off...But the WORST part is that the PTO disengages randomly as I am mowing...after a bump, on smooth ground, mowing slow, mowing fast, mowing for a short bit, mowing for a long bit....I have looked for a pattern, but found nothing.
This has been happening off and on since last year, but seems a bit worse this year.
Both belts replaced this year, took apart the mower and the spindles and cleaned them, and put in a new PTO switch. Nothing helped, although it looks nice
Battery is a WalMart cheapo - 235 cold cranking amps (enough power???)
Any ideas, or do I need to just take it in?
Thank you!
Dal
Thank you!
Dal
