Repairs Lt 2000 suddenly won't turn over
Moegs
After mowing, I brought it in to clean it up. When I tried to start it to move it to it's parking space, it wouldn't turn over. Have lights and a fresh battery. Started some testing of the interlock switches (seat, brake/clutch pedal, and belt drive. All checked out good with multi -meter. Battery shows 12.5 volts. Checked wiring and ground connections..all appear good. Not sure about ignition switch as I don't know which terminals to touch with the meter. Wiring diagram shows three terminals, B, S, and A1 for the start circuit. Engine is a Honda 16 HP twin with the solenoid mounted on the starter. Before I jump the starter, I want to know if this is done by touching the spade terminal (with the white wire) to the red power terminal with a screwdriver. I used to do this on cars back in the day to bypass the ignition switch. I don't want to damage anything so any advice you can give would be greatly appreciated. Thanks a bunch!!
KennyV
If you jump from the Large terminal (coming from the battery + terminal).... to the small terminal.... it should spin the starter... If the key is on It should start... :smile:KennyV
Moegs
Thanks Kenny
There is a weak spark when jumping the solenoid, so, a bad battery. Duh..I should have checked it out, but I couldn't believe the battery would all of a sudden crap out when it was running fine. Chalk it up to lessons learned.
benski
Before you toss that battery, you might charge it up again (GENTLY!) and take it to a place that has a battery load tester. As an aside, I've had lousy luck with batteries from Wal-Mart.:ashamed::mad: Uh, I'm shocked...:rolleyes:
