After parking my tractor down a steep hill (nose first) I can't get it to start. I've rolled it down to a flat area. It has fuel in the tank. I haven't checked spark yet. Any idea I what I should do next?
Service Mower Check oil level first, read troubleshooting.
Check air filter, fuel filter & spark plug for replacement. Post engine manufacturer as well as numbers, example: B&S ENGINE model xxxxxx, type xxxx, trim xx. Rotate top of engine with both hands clockwise just past hard spot & try cranking with key, if it cranks you need to adjust valves.
All troubleshooting tips were checked before posting. Is there something that the incline could have done to keep this from firing now? It cranks over fine.
Could be a couple of things, bad fuel pump or air lock, preventing fuel from getting to the carb. No spark, unrelated to parking, need to be checked. Check for spark, if you have spark spray some carb cleaner directly into the carb air horn after removing the air cleaner. Post back.
