Hi everyone,
I have a 2007 lt 1045 with a 20 hp Kohler engine. I have a new battery in it as well as a new starter. When I tried to start it you can see the starter jump up to the fly wheel and try to turn it but it wouldn't turn. I kept bumping the starter several times and it finally turned the engine over. I have tried it many more times since then and it starts every time. I still believe something is not right, it seems like at times it has to much compression and cant turn over. All along I thought it was the battery going bad but now i believe it was not the battery.
Any input as to what one may think the problem is would be much appreciated.
Thanks for your time.
