cruzenmike
Gator blades and a plug do not turn your mower deck into a mulching deck. They turn it into a side discharge deck with the discharge plugged shut. I suspect you will be disappointed with that setup.
A true mulching deck (or a side discharge deck with a mulch kit) creates separate chambers, each of which holds the clippings in and allows them to be chopped up before falling down into the turf.
Just plugging the discharge without using a true mulch kit allows the deck to throw all the clippings over to the discharge side where they will accumulate and leave a trail of clippings behind the right hand side of the deck.
I get what you are saying. A few things that threw me were that all of the stamped Toro decks (of which I recently owned one) have one single cutting chamber for their mulch kits. The OEM mulch kit for my LTX1050 is just a plug. If Cub Cadet engineered the mower to just be plugged to "mulch" then at that point it's just a matter of what blade to go with? Would the plug simply do better with low lift blades then? The gator style blades, with their extra cutting surface(s) should re-cut the clippings a bit more than a regular high lift blade that is intended to just clear the deck?
