LT1045wrh
Hi Everyone,
I have a 42" Murray Select 2004, w/17.5hp BS motor, 6 spd manual trans. I was mowing yesterday and noticed a squeaking noise coming from the rear axle, I think. It's hard to hear exactly where the squeak is coming from, but that's where it sounds like. Anyway, I've had this mower since it was new and as you can see, it is pretty old and used. Do I need to change the trans. fluid, or add fluid? If so, does anyone have any information about this?
After about an hour's worth of mowing, I felt the transmission housing and it wasn't hot, just warm. This has been a great mower, so I want to fix it if something is going wrong. It never had this squeak before, so I consider it a warning.
Thank you,
Wendy :biggrin:
Thank you,
Wendy :biggrin:
