"How freely does the deck system (pulleys,spindles,clutch and belts) move when not engaged?" ..... The pulleys, belts, blades turn easily when not engaged.
"Well you have either not cleaned the carb, reassembled the carb wrong or hooked it up wrong." ..... I didn't remove the carb, I just sprayed cleaner down the throat.
Does anyone know if there's any way of checking the fuel pump for proper operation? I forgot to mention that I have blown out all fuel lines when I replaced the fuel filter.
