GearHead36
I recently took apart my Stihl MS 192 TC chainsaw to clean it and rebuild the carb. I found that the muffler was completely loose. I found one of the two bolts needed. I reinstalled the muffler with the one bolt, and cranked it to see if it made it quieter. IMO, that saw was way too loud for such a small saw. It was quieter, but the muffler started moving around after about 5 seconds. The one bolt had already loosened. I tried the bolt in the other mount hole, but it wouldn't go. I suspect the threads are carboned up. So I need to find a tap to chase the threads, and get another bolt. But even if I do, will the bolts stay tight? Is there some sort of high temp thread locker I need to use?
