Hammermechanicman
- Jan 10, 2020
- 69
- 3,940
Usually get to them with a crowsfoot wrench.
For your reader search for "K type thermocouple reader" Amazon.com has one for $10.49During the winter, I'm gonna be pulling the engine (Briggs 24HP twin) due to the oil sump gasket leaking badly. I'm gonna inspect and reseal the engine as well as take care of maintenance it needs as the tractor has +/- 600 hours on it and I know not all of the required maintenance has been done on it.
Although the engine is air cooled, I've been thinking I'd like to add a temperature gauge because I'd like to keep an eye on it. It hasn't been acting as if it's running hot at all, but since I'm gonna have the engine out and disassembled, I figured it's as good a time as any to add one. I was wondering if anyone has added a gauge to one of these engines, where you installed the sensor, and what brand sensor/gauge did you use? I've found plenty of sensor/gauge kits for water cooled models but they include sensors intended to be mounted in a cooling passage. I did find a head temp sensor that would be very easy to install (https://www.amazon.com/Cylinder-Hea...instruments+temp+sensor&qid=1604018011&sr=8-5) but it doesn't include a gauge and I'm not totally sure what it would need. My experience is with negative temp coefficient sensors but I haven't yet found time to determine if that's what this sensor is.
I was also curious if there's any other suggestions for what I should do while the engine is out. I'm planning to replace the steering shaft gear as it's stripped and the front spindles as they are worn. The tractor is in overall good condition, it just needs a little TLC.
I'm a professional auto mechanic and we also do plenty of small engine work at my shop so I'm not at all intimidated by anything on this mower - just need some tips and suggestions.
Thanks.
