Looking for help to find a reciole spring on eBay for my homelight hb25150 leafblower
  • / Looking for help to find a reciole spring on eBay for my homelight hb25150 leafblower
I just looked up these two tell me which one is close to my stock one NOS HOMELITE 180 190 192 200 240 250 Chainsaw Recoil Starter Spring A97908 and Homelite 308066001 Spring & Container Assembly
Part#: 308066001
And probably need a new starter pulley too. PN 98770A as both of the original parts have been superseded.
I don't know if u could tell me but my stock one before it brock it would kickback out of the case and not rewind it it hasn't done that before and when I would rewind with my hand it would click 2 times and it never do it maybey would the spring be wore out or my pully because I put the new one in it is a small head and it does the same thing but 10 times worse so I know for a fact the new is the rong size if u could help me find the right recoile I pictured is the dirty one that would be helpful thanks
All we can go by is the published IPLs for your UT-08034-R. The original PN for the recoil spring and retainer was UP03917 which was superseded to A98773A and finally the latest supersede is PN 638033001.
Also make sure you are winding in the correct direction.
Ok thank u for ure time I ordered the recoile ure talking bout I think it's my pully so I will go from there
When you say kick out of the case, are you saying that the exterior bump is hopping out of its recess area in the blower housing. Or the spring is disconnecting from the rope pulley.
It's poping out of the blower housing and it disconnect from the pully
When you look where the spring goes into the blower housing there is a recess area that the bump fits into. there should be a pin in the center of that recess area. Is that pin still there or has it broken off.
I know part of the hole were the spring goes is chipped of but still fits
