LawnBoy97
- May 30, 2012
- 33
- 223
Okay, the initial impressions are that it has great power and is light-weight (I think I need to adjust the handle, though, as there was significantly more weight on my right arm) and it is very easy to edge sidewalks with. I am not sure if it was because of how much grass I was removing from the sidewalk, but it did seem to be getting pretty hot after maybe like five or so minutes of edging. I am hoping this is only due to the amount of grass, though.It is very easy to start. Just flip the choke switch, pull a couple of times until it starts and then let it idle for a few seconds. Then just pull the throttle and go. I do like the design of the motor housing, as well as the size of the guard, but the rewinding the head seems very complicated. I don't want to count this as a negative just yet, though, as I hadn't even looked at the instructions when I had tried to rewind it, so I think it should be fine.
So to sum it all up:
Positives-
-Great for edging
-Great Power
-Fairly good design
Negatives-
-Possibly complicated to rewind
-That's about it
I'll make sure to keep everyone updated and hopefully I can post some pictures this evening. Thanks
Positives-
-Great for edging
-Great Power
-Fairly good design
Negatives-
-That's about it
